Ana içeriğe geç
Verizon Ellipsis 10 Camera Replacement
Neye ihtiyacın var
  1. Verizon Ellipsis 10 Camera Replacement, Back Cover: adım 1, 1 resimden 1.
    • Open the SD/SIM card cover to start prying off the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Verizon Ellipsis 10 Camera Replacement: adım 2, 1 resimden 1.
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
    FixBot'a Sor
    Yorum Ekle
  3. Verizon Ellipsis 10 Camera Replacement: adım 3, 1 resimden 1.
    • Follow along the edge of the device to undo all of the retaining clips.
    FixBot'a Sor
    Yorum Ekle
  4. Verizon Ellipsis 10 Camera Replacement: adım 4, 1 resimden 1.
    • Once all the clips are undone, the back panel should come off with little effort.
    FixBot'a Sor
    Yorum Ekle
  5. Verizon Ellipsis 10 Camera Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
    FixBot'a Sor
    Yorum Ekle
  6. Verizon Ellipsis 10 Camera Replacement: adım 6, 1 resimden 1.
    • Remove the top piece of tape using an iFixit opening tool.
    FixBot'a Sor
    Yorum Ekle
  7. Verizon Ellipsis 10 Camera Replacement: adım 7, 1 resimden 1.
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
    FixBot'a Sor
    Yorum Ekle
  8. Verizon Ellipsis 10 Camera Replacement: adım 8, 1 resimden 1.
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
    FixBot'a Sor
    Yorum Ekle
  9. Verizon Ellipsis 10 Camera Replacement: adım 9, 1 resimden 1.
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
    FixBot'a Sor
    Yorum Ekle
  10. Verizon Ellipsis 10 Camera Replacement, Camera: adım 10, 1 resimden 1.
    • Remove 4 M1.5 screws holding in the labeled LTE module.
    FixBot'a Sor
    Yorum Ekle
  11. Verizon Ellipsis 10 Camera Replacement: adım 11, 1 resimden 1.
    • Use a nylon spudger to pry up the module.
    • It's held in with some clips so there will be a little bit of resistance.
    FixBot'a Sor
    Yorum Ekle
  12. Verizon Ellipsis 10 Camera Replacement: adım 12, 2 resimden 1. Verizon Ellipsis 10 Camera Replacement: adım 12, 2 resimden 2.
    • Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
    • The module should come up with a little resistance.
    FixBot'a Sor
    Yorum Ekle
  13. Verizon Ellipsis 10 Camera Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to lift up the front camera off its locating post.
    FixBot'a Sor
    Yorum Ekle
  14. Verizon Ellipsis 10 Camera Replacement: adım 14, 2 resimden 1. Verizon Ellipsis 10 Camera Replacement: adım 14, 2 resimden 2.
    • Remove the non-conductive tape covering the camera ribbon cable.
    • You may need to remove the white antenna cable to remove the tape.
    FixBot'a Sor
    Yorum Ekle
  15. Verizon Ellipsis 10 Camera Replacement: adım 15, 1 resimden 1.
    • Carefully unplug the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  16. Verizon Ellipsis 10 Camera Replacement: adım 16, 2 resimden 1. Verizon Ellipsis 10 Camera Replacement: adım 16, 2 resimden 2.
    • Peel up the ribbon cable carefully as it is glued to the device.
    • After having peeled up the cable, the cameras should be free to come out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 314
