Ana içeriğe geç
Verizon Ellipsis 10 Motherboard Replacement
Neye ihtiyacın var
  1. Verizon Ellipsis 10 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Motherboard Replacement: adım 2, 1 resimden 1.
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Motherboard Replacement: adım 3, 1 resimden 1.
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Motherboard Replacement: adım 4, 1 resimden 1.
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Motherboard Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Motherboard Replacement: adım 7, 1 resimden 1.
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Motherboard Replacement: adım 8, 1 resimden 1.
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Motherboard Replacement: adım 9, 1 resimden 1.
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Motherboard Replacement, Camera: adım 10, 1 resimden 1.
    • Remove 4 M1.5 screws holding in the labeled LTE module.
  11. Verizon Ellipsis 10 Motherboard Replacement: adım 11, 1 resimden 1.
    • Use a nylon spudger to pry up the module.
    • It's held in with some clips so there will be a little bit of resistance.
  12. Verizon Ellipsis 10 Motherboard Replacement: adım 12, 2 resimden 1. Verizon Ellipsis 10 Motherboard Replacement: adım 12, 2 resimden 2.
    • Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
    • The module should come up with a little resistance.
  13. Verizon Ellipsis 10 Motherboard Replacement: adım 13, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to lift up the front camera off its locating post.
  14. Verizon Ellipsis 10 Motherboard Replacement: adım 14, 2 resimden 1. Verizon Ellipsis 10 Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove the non-conductive tape covering the camera ribbon cable.
    • You may need to remove the white antenna cable to remove the tape.
  15. Verizon Ellipsis 10 Motherboard Replacement: adım 15, 1 resimden 1.
    • Carefully unplug the ribbon cable from the motherboard.
  16. Verizon Ellipsis 10 Motherboard Replacement: adım 16, 2 resimden 1. Verizon Ellipsis 10 Motherboard Replacement: adım 16, 2 resimden 2.
    • Peel up the ribbon cable carefully as it is glued to the device.
    • After having peeled up the cable, the cameras should be free to come out of the device.
  17. Verizon Ellipsis 10 Motherboard Replacement, Motherboard: adım 17, 1 resimden 1.
    • Remove the non-conductive tape covering two ribbon cables.
  18. Verizon Ellipsis 10 Motherboard Replacement: adım 18, 1 resimden 1.
    • Gently unplug both the orange and white ribbon cables.
  19. Verizon Ellipsis 10 Motherboard Replacement: adım 19, 1 resimden 1.
    • Use tweezers to pry/disconnect both the black and white antenna cables from the top of the motherboard.
  20. Verizon Ellipsis 10 Motherboard Replacement: adım 20, 1 resimden 1.
    • Unplug the last ribbon cable from the bottom of the motherboard.
  21. Verizon Ellipsis 10 Motherboard Replacement: adım 21, 1 resimden 1.
    • Remove all M1.5 screws holding in the motherboard.
  22. Verizon Ellipsis 10 Motherboard Replacement: adım 22, 1 resimden 1.
    • Once all screws are removed, the motherboard should easily come off the device without any resistance.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
my Verizon se apaga cuando subo el volumen,que sera?
Gabriela Monti - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 379
