Ana içeriğe geç
Verizon Ellipsis 7 Battery Replacement
Neye ihtiyacın var
    1. Verizon Ellipsis 7 Battery Replacement, Battery: adım 1, 3 resimden 1. Verizon Ellipsis 7 Battery Replacement, Battery: adım 1, 3 resimden 2. Verizon Ellipsis 7 Battery Replacement, Battery: adım 1, 3 resimden 3.
      • Power down device by holding down the power button until the screen goes black.
      • Remove the SIM card from the device to prevent damage.
      • To remove the SIM card, open the SIM card cover on the side of the device.
      • Push SIM card in and then pull out after hearing a click.
      FixBot'a Sor
      Yorum Ekle
    2. Verizon Ellipsis 7 Battery Replacement: adım 2, 2 resimden 1. Verizon Ellipsis 7 Battery Replacement: adım 2, 2 resimden 2.
      • Take off the back panel.
      • Pry open the back cover carefully with a plastic opening tool.
      • Use the opening tool to disconnect the cover completely. Do not attempt to pull the back cover off with your hands.
      • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
      FixBot'a Sor
      Yorum Ekle
    3. Verizon Ellipsis 7 Battery Replacement: adım 3, 3 resimden 1. Verizon Ellipsis 7 Battery Replacement: adım 3, 3 resimden 2. Verizon Ellipsis 7 Battery Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
      • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
      • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
      • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Scott Mangin
609 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-5, Banghart Winter 2017 Cal Poly, Team 13-5, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S13G5
4 Üyeler
12 adet Kılavuz yazıldı
8Kılavuz Yorumları
so much for the charging port. You didn’t mention the battery. ?
good1946scout - Yanıt Paylaş
Well….ok…..but were we here for removing the charging port? Ha ha….I think not. So how about we lift out the battery and unplug it instead. Takes a bit of effort , it seems. That sucker is stuck down pretty good with some really good double sided tape. Lift carefully. I pried it up with the same plastic case tool I used to remove the back cover. The same tool also helped me remove the battery plug.
David Shaw - Yanıt Paylaş
First time on Ifixit and they leave me two steps from the goal; not much of a confidence-builder for this site!
Groove - Yanıt Paylaş
WTH? Replacing the battery?
kaycha12 - Yanıt Paylaş
Look at the stats..
Why suddenly are so many units failing at or about the same time? I'm not a conspirist but,
Don't you think it's a strange coincidence?
Kermit Allison - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 54
Her zaman: 30,661
