Ana içeriğe geç
Verizon Ellipsis 8 Button Replacement
Neye ihtiyacın var
  1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: adım 1, 1 resimden 1.
    • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
    FixBot'a Sor
    Yorum Ekle
  2. Verizon Ellipsis 8  Button Replacement: adım 2, 1 resimden 1.
    • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
    FixBot'a Sor
    Yorum Ekle
  3. Verizon Ellipsis 8  Button Replacement: adım 3, 1 resimden 1.
    • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jack
610 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S18-G6, Lore Winter 2019 UC Davis, Team S18-G6, Lore Winter 2019 üyesi
UCD-LORE-W19S18G6
3 Üyeler
1Rehber Yorum
where can i purchase replacement buttons for this device? anyone know? Thanks!!!
Broadcast Depth - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 34
Her zaman: 780
