Ana içeriğe geç
Verizon Ellipsis 8 Antenna Replacement
Neye ihtiyacın var
  1. Verizon Ellipsis 8 Antenna Replacement, Battery: adım 1, 1 resimden 1.
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Antenna Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Antenna Replacement: adım 3, 1 resimden 1.
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Antenna Replacement: adım 4, 1 resimden 1.
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Antenna Replacement, Antenna: adım 5, 1 resimden 1.
    • Using a plastic opening tool, lift the motherboard along the top right edge of the device.
  6. Verizon Ellipsis 8 Antenna Replacement: adım 6, 3 resimden 1. Verizon Ellipsis 8 Antenna Replacement: adım 6, 3 resimden 2. Verizon Ellipsis 8 Antenna Replacement: adım 6, 3 resimden 3.
    • Once you have access to the antenna, remove it and replace it.
Sonuç
Jack
589 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S18-G6, Lore Winter 2019 UC Davis, Team S18-G6, Lore Winter 2019 üyesi
UCD-LORE-W19S18G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 248
