Ana içeriğe geç
Verizon Ellipsis 8 Screen Replacement
Neye ihtiyacın var
  1. Verizon Ellipsis 8 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Screen Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Screen Replacement: adım 3, 1 resimden 1.
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Screen Replacement: adım 4, 1 resimden 1.
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Screen Replacement, Speaker: adım 5, 3 resimden 1. Verizon Ellipsis 8 Screen Replacement, Speaker: adım 5, 3 resimden 2. Verizon Ellipsis 8 Screen Replacement, Speaker: adım 5, 3 resimden 3.
    • Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
    • Remove the speaker from the device.
  6. Verizon Ellipsis 8 Screen Replacement, Screen: adım 6, 1 resimden 1.
    • Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sreedhar Kesari
190 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Stella Fall 2019 IUPUI, Team S2-G2, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S2G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,028
