Ana içeriğe geç
Verizon Ellipsis Jetpack MHS800L Screen Replacement
Neye ihtiyacın var
  1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: adım 1, 3 resimden 1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: adım 1, 3 resimden 2. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: adım 1, 3 resimden 3.
    • Remove the SIM card, that is located on top of the Jetpack.
    FixBot'a Sor
    Yorum Ekle
  2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 2, 3 resimden 1. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 2, 3 resimden 2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
    FixBot'a Sor
    Yorum Ekle
  3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 3, 1 resimden 1.
    • Remove three 1.25 mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 4, 1 resimden 1.
    iFixit Opening Picks (Set of 6)
    $4.95
    FixBot'a Sor
    Yorum Ekle
  5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 5, 1 resimden 1.
    • Once the cover is off, this is what your device will look like.
    FixBot'a Sor
    Yorum Ekle
  6. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: adım 6, 2 resimden 1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: adım 6, 2 resimden 2.
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
    FixBot'a Sor
    Yorum Ekle
  7. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 7, 2 resimden 1. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 7, 2 resimden 2.
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
    FixBot'a Sor
    Yorum Ekle
  8. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 8, 1 resimden 1.
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
    FixBot'a Sor
    Yorum Ekle
  9. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 9, 1 resimden 1.
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
    FixBot'a Sor
    Yorum Ekle
  10. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: adım 10, 3 resimden 1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: adım 10, 3 resimden 2. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: adım 10, 3 resimden 3.
    • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
    FixBot'a Sor
    Yorum Ekle
  11. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 11, 2 resimden 1. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 11, 2 resimden 2.
    • Using the Tweezers gently coax the display data cable out of circuit board connector.
    • Do not squeeze the display data cable to hard you may damage it and cause a short.
    FixBot'a Sor
    Yorum Ekle
  12. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 12, 2 resimden 1. Verizon Ellipsis Jetpack MHS800L Screen Replacement: adım 12, 2 resimden 2.
    • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Richard J Porras
504 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Baechle Spring 2016 IUPUI, Team 3-3, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S3G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 2,488
