Ana içeriğe geç
Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement
Neye ihtiyacın var
  1. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: adım 1, 2 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: adım 2, 2 resimden 1. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: adım 2, 2 resimden 2.
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: adım 3, 1 resimden 1.
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
Sonuç
Analisa Caso
232 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team S1-G3, Chaterdon Fall 2018 Marist, Team S1-G3, Chaterdon Fall 2018 üyesi
MARS-CHATERDON-F18S1G3
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 4,767
