Ana içeriğe geç
Tehlike
Tehlikeli Olma Potansiyeli Var
Bu talimat doğru şekilde uygulanmazsa yaralanma meydana gelebilir. Dikkatli olun ve tüm uyarıları takip edin.
Tehlike
Giriş
The capacitor is located on the circuit board. You will need to solder in order to replace the capacitor. For help with soldering techniques, click here.
  1. Flip the device so that the bottom is facing up.
    • Flip the device so that the bottom is facing up.
  2. Insert the plastic-opening tool under the silver labeled casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  6. Locate the two 10-mm screws on either side of the circuit board. Unscrew the two 10-mm screws using a Phillips #0 screwdriver. Keep track of the red rubber washer you remove from underneath one of the screws.
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  7. Lift the front of the circuit board up from the bottom casing.
    • Lift the front of the circuit board up from the bottom casing.
  8. Pull the circuit board towards you until it is separate from the bottom casing.
    • Pull the circuit board towards you until it is separate from the bottom casing.
  9. Locate the capacitor.
    • Locate the capacitor.
  10. Flip the circuit board over.
    • Flip the circuit board over.
    • Locate the two prongs on the flip side that are attached to the capacitor on the top side.
  11. Touch the hot soldering iron to each prong in order to melt the solder around them. Flip the circuit board and pull out the capacitor from its place while the solder is still hot. For help with soldering techniques, click here.
    • Touch the hot soldering iron to each prong in order to melt the solder around them.
    • Flip the circuit board and pull out the capacitor from its place while the solder is still hot.
    • For help with soldering techniques, click here.
  12. Insert the new capacitor through the circuit board so that the prongs are exposed on the flip side. Heat the prongs up with the soldering iron and touch a soldering wire to the hot prongs to attach the capacitor to the board. Heat the prongs up with the soldering iron and touch a soldering wire to the hot prongs to attach the capacitor to the board.
    • Insert the new capacitor through the circuit board so that the prongs are exposed on the flip side.
    • Heat the prongs up with the soldering iron and touch a soldering wire to the hot prongs to attach the capacitor to the board.
Sonuç
To reassemble your device, follow Steps 1-7 in reverse order.
Jeffrey Fox
326 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 335
