Ana içeriğe geç
Verizon M1424WR Motherboard Replacement
Neye ihtiyacın var
  1. Verizon M1424WR Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Motherboard Replacement: adım 2, 3 resimden 1. Verizon M1424WR Motherboard Replacement: adım 2, 3 resimden 2. Verizon M1424WR Motherboard Replacement: adım 2, 3 resimden 3.
    • Warning: The design and location of the plastic clips holding this shroud make it extremely difficult to release. Take your time and use a second pry tool if necessary.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Motherboard Replacement: adım 3, 2 resimden 1. Verizon M1424WR Motherboard Replacement: adım 3, 2 resimden 2.
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Motherboard Replacement: adım 4, 2 resimden 1. Verizon M1424WR Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Motherboard Replacement: adım 5, 3 resimden 1. Verizon M1424WR Motherboard Replacement: adım 5, 3 resimden 2. Verizon M1424WR Motherboard Replacement: adım 5, 3 resimden 3.
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  6. Verizon M1424WR Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift the front of the circuit board up from the bottom casing.
  7. Verizon M1424WR Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull the circuit board towards you until it is separate from the bottom casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeffrey Fox
347 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 753
