Ana içeriğe geç
Verizon Wireless CDM 7075 Keypad Replacement
Neye ihtiyacın var
  1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: adım 1, 2 resimden 1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
    FixBot'a Sor
    Yorum Ekle
  2. Verizon Wireless CDM 7075 Keypad Replacement: adım 2, 1 resimden 1.
    • Carefully remove the battery from the phone by prying the battery from the top.
    FixBot'a Sor
    Yorum Ekle
  3. Verizon Wireless CDM 7075 Keypad Replacement, Keypad: adım 3, 1 resimden 1.
    • Pry off the top cover on the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Verizon Wireless CDM 7075 Keypad Replacement: adım 4, 1 resimden 1.
    • You will then remove the screws from the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Verizon Wireless CDM 7075 Keypad Replacement: adım 5, 1 resimden 1.
    • Next you will pry apart the two halves of the phone.
    • Make sure you do not to damage the ribbon cable connecting both halves
    FixBot'a Sor
    Yorum Ekle
  6. Verizon Wireless CDM 7075 Keypad Replacement: adım 6, 1 resimden 1.
    • Then use the plastic opening tool to remove the motherboard from the front half of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Verizon Wireless CDM 7075 Keypad Replacement: adım 7, 1 resimden 1.
    • Next you will peel off the keypad after the motherboard is removed.
    • Be sure you do not to tear the brown connector tape.
    • Lastly insert the new keypad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Corey Ryman
255 İtibar
4 adet Kılavuz yazıldı
Ekip
James Madison, Team 2-4, Allen Fall 2011 James Madison, Team 2-4, Allen Fall 2011 üyesi
JMU-ALLEN-F11S2G4
3 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 1,500
