Ana içeriğe geç
Giriş
Please ensure you have followed the prerequisite guide of removing the battery before proceeding with this guide.
  1. To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off. To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
    • To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
  2. Carefully remove the battery from the phone by prying it from the top.
    • Carefully remove the battery from the phone by prying it from the top.
  3. With the opening tool, remove the rubber plugs from the screw holes around the screen.
    • With the opening tool, remove the rubber plugs from the screw holes around the screen.
  4. With a Philips screwdriver, remove the four screws from around the phone's screen.
    • With a Philips screwdriver, remove the four screws from around the phone's screen.
  5. Pry the top cover off the phone with a plastic opening tool.
    • Pry the top cover off the phone with a plastic opening tool.
  6. Remove the screen assembly from the phone.
    • Remove the screen assembly from the phone.
  7. With the opening tool, pry the circuit board off of the screen.
    • With the opening tool, pry the circuit board off of the screen.
Sonuç
Corey Ryman
255 İtibar
4 adet Kılavuz yazıldı
Takım
James Madison, Team 2-4, Allen Fall 2011 James Madison, Team 2-4, Allen Fall 2011 üyesi
JMU-ALLEN-F11S2G4
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 945
