Ana içeriğe geç
VersaMed iVent 201 Power Pack Replacement
Neye ihtiyacın var
  1. VersaMed iVent 201 Power Pack Replacement, Power Pack: adım 1, 1 resimden 1.
    • Remove the four 3mm x 20mm Phillips screws located on the corners of the power pack.
    FixBot'a Sor
    Yorum Ekle
  2. VersaMed iVent 201 Power Pack Replacement: adım 2, 1 resimden 1.
    • Pull the power pack from the compartment using black handle.
    FixBot'a Sor
    Yorum Ekle
  3. VersaMed iVent 201 Power Pack Replacement: adım 3, 1 resimden 1.
    • Remove the five 3mm x 10mm Phillips screws and washers from the back of the power pack. Lift off the cover after.
    FixBot'a Sor
    Yorum Ekle
  4. VersaMed iVent 201 Power Pack Replacement: adım 4, 1 resimden 1.
    • Turn the battery pack upside down and take the battery out of the casing.
    • When reassembling, listen for the sound of the cooling fan for confirmation that the connection was successful.
    FixBot'a Sor
    Yorum Ekle
  5. VersaMed iVent 201 Power Pack Replacement: adım 5, 1 resimden 1.
    • Remove the two spade connectors using pliers.
    • When assembling the power pack, MAKE SURE to connect the red wire to the positive terminal and the black wire to the negative terminal of the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Caution: MAKE SURE THE RED WIRE IS CONNECTED TO THE POSITIVE TERMINAL AND THE BLACK WIRE IS CONNECTED TO THE NEGATIVE.
Jeffrey Yin
265 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G17, Paton Spring 2020 Cal Poly, Team S7-G17, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G17
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 502
