Giriş
This guide will show you how to change the oil in large-frame Vespa scooters. This guide uses a 1997 T5 motor installed in a 1959 Vespa 150, but the procedure and locations of all parts are the same for all Vespa Large Frame scooters (Vespa 125 VNA/VNB, 150 VBA/VBB, 125/150 Super, Sprint, GS160, SS180, Rally 180/200, all PX models, Indian manufactured Bajaj and LML 2-stroke models, and more.)
Neye ihtiyacın var
For the best access to the oil drain plug, and for optimal oil drainage, it is recommended that the scooter be stood upright.
Using your hand, pull the engine cover retaining latch away from the scooter frame, then twist the latch clockwise to release the engine cover.
Place an oil drain pan below the engine to catch the used oil.
Using an 10mm socket, unscrew the oil drain plug
Remove the oil drain plug, letting the oil drain out of the engine.
Wait for almost all of the oil to drain out of the engine, about five minutes.
Using your fingers, re-install and hand tighten the oil drain plug.
Using a 10mm socket, tighten the oil drain plug.
Using your hands, insert and hand-tighten the oil fill plug.
Using a large flathead screwdriver, tighten the oil fill plug.
There is no necessary torque specification for the oil fill plug. However, make sure that it is tight enough that it doesn't rattle out. It also should not be so tight that the threads strip.
16 farklı kişi bu kılavuzu tamamladı.
3 Yorum
What about the oil to flush the engine before filling up ?
It's been recommend by VESPA drivers...
What do you think about that and what *type* of oil a VESPA will take?
10-50? 20-50? Or a standard thickness?
I have a 1986 LML 150 model.
Please reply.
Thank you.
Oil. SAE 30. Non-detergent type, aka ND30
