Ana içeriğe geç
Vicks FilterFree Plus Fan Replacement
Neye ihtiyacın var
    1. Vicks FilterFree Plus Fan Replacement, Tank Cap: adım 1, 1 resimden 1.
      • Ensure the device is clear of water before disassembling.
      • Orient the device so the nozzle is facing the ceiling.
      • Twist off the primary water holding cap.
      FixBot'a Sor
      Yorum Ekle
    2. Vicks FilterFree Plus Fan Replacement: adım 2, 2 resimden 1. Vicks FilterFree Plus Fan Replacement: adım 2, 2 resimden 2.
      • Place the device upside down so that the tank cap is facing you.
      • Use your hands to twist the tank cap and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Vicks FilterFree Plus Fan Replacement, Fan: adım 3, 2 resimden 1. Vicks FilterFree Plus Fan Replacement, Fan: adım 3, 2 resimden 2.
      • Remove the three screws from the base of the device using a T20 Torx screwdriver.
      • Remove the base of the humidifier to access the components.
      FixBot'a Sor
      Yorum Ekle
    2. Vicks FilterFree Plus Fan Replacement: adım 4, 2 resimden 1. Vicks FilterFree Plus Fan Replacement: adım 4, 2 resimden 2.
      • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
      FixBot'a Sor
      Yorum Ekle
    3. Vicks FilterFree Plus Fan Replacement: adım 5, 3 resimden 1. Vicks FilterFree Plus Fan Replacement: adım 5, 3 resimden 2. Vicks FilterFree Plus Fan Replacement: adım 5, 3 resimden 3.
      • Remove the fan by disconnecting its wire from the board.
      • Gently remove the fan from the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Logan Pianfetti
97 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-5, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G5
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,684
