Ana içeriğe geç
Video Guide Rancilio Silvia Grouphead Screen And Gasket Replacement Grouphead Gasket & Screen Replacement
Neye ihtiyacın var
    • Identification instructions.
    • Remove water tank, hoses, and tuck them back in the machine.
    • Remove drip tray. Flip the machine upside down.
    • Remove screen screw with flat head screwdriver.
    • Remove old screen and diffuser.
    • Remove and soak diffuser in Joe Glo coffee cleaner.
    • On version 3 you will need to remove and soak the brass disc as well.
    • Pry the gasket up with the sharp tip of the awl.
    • Carefully remove old gasket.
    • Use Joe Glo coffee cleaner and hot water to soak the grouphead for 10-15 minutes.
    • A dental pick works great for cleaning the grouphead.
    • Use a small flathead to clean the bottom surface of the grouphead.
    • A small stainless steel brush works well. They can be found at your local hardware store.
    • Use a paper towel / regular towel to soak the dirty water from the grouphead.
    • Use the compressed air can to clean any excess water or coffee.
    • Last but not least, use the pick on the top and bottom rails to remove last bits of coffee debris.
    • Remove parts from bag.
    • Take the new gasket and install it with the lettering down.
    • Use a 1/4 inch flat punch to push down the gasket to ensure its nice and flat.
    • Insert the diffuser with the water channels facing down.
    • Use an 8mm socket wrench to tighten the screw.
    • Careful not to over tighten and break screw. It will be extremely difficult to remove.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Samuel Kanenwisher
1.230 İtibar
2 adet Kılavuz yazıldı
Ekip
Kanen Coffee: Espresso Machines Kanen Coffee: Espresso Machines üyesi
Business
1 Üye
7 Yorum
Perfect - Just what I needed for my machine.
casper.svendsen - Yanıt
Nice job! Made it easy to clean and install new partS.
Dan Myall - Yanıt
very well done. going to do it with my silvia this weekend.
Tom Manaves - Yanıt
Best version I’ve seen so far. Showing how it’s done on a dirty machine helps
Richard G - Yanıt
Great!!! I’m assuming the fully assembled backflush procedure is unnecessary after this. But I was wondering if there are any hidden crevices that backflush would get to. This is more serious than you think in my case… I’m resurrecting a rarely used, 15 year old V1 that has NEVER been serviced.
Jeff Vandegrift - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 9,323
