Ana içeriğe geç
HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement
Neye ihtiyacın var
  1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Batteries: adım 1, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Batteries: adım 1, 2 resimden 2.
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 3, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 3, 2 resimden 2.
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 4, 1 resimden 1.
    • Pull out the batteries.
  4. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Plastic Casing: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 6, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 6, 2 resimden 2.
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 7, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 7, 2 resimden 2.
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 8, 3 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 8, 3 resimden 2. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 8, 3 resimden 3.
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 9, 1 resimden 1.
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 10, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 10, 2 resimden 2.
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
  10. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, LCD Screen: adım 11, 1 resimden 1.
    • Orient the camera so that the LCD screen is facing you.
    • If case is still on, remove it by following the Plastic Casing Installation Guide found in the previous steps.
    • Removing the casing completely is crucial to completing this guide.
  11. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 12, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 12, 2 resimden 2.
    • Using a Phillips #00 remove the four 4.40 mm screws that secure the LCD screen to the frame.
  12. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 13, 1 resimden 1.
    • Allow the LCD screen to flip down. This will expose the electric strip that connects the screen to the camera.
  13. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 14, 1 resimden 1.
    • Look for where the yellow electric strip is attached to the camera. You will find a plastic grey bar and a white base holding this strip in place.
    • Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
  14. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 15, 1 resimden 1.
    • Unplug the connected red and white wires. They will come out with the small white casing.
  15. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 16, 1 resimden 1.
    • Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
  16. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 17, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 17, 2 resimden 2.
    • Remove the bottom left LCD mounting frame screw. The screen should come loose after the screw is removed.
    • Remove the LCD screen from the camera. Make sure that the electric strip comes out with screen.
  17. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Viewfinder Mirror and Lens: adım 18, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the two screws securing the electric strip casing on the back of the camera.
  18. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 19, 1 resimden 1.
    • On the top of the camera where the shutter button is located, remove the screws located near the speaker that secure the electric strip casing.
  19. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 20, 1 resimden 1.
    • Turn the camera over to the side that once housed the LCD screen. Locate the electric strip near the top of the camera.
    • Holding the camera securely, gently pull the end of the electric strip off of the back of the camera using a pair of tweezers.
  20. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 21, 1 resimden 1.
    • Ensure there are two ends of the electric strip detached from the camera.
  21. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 22, 1 resimden 1.
    • Using your fingers, fully detach the strip along with the casing. Be careful not to rip or tear any part of the electric strip.
    • Do not break or remove the black wire. This will damage the camera.
  22. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 23, 2 resimden 1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 23, 2 resimden 2.
    • Orient the camera so that you are looking at the back of the camera. Directly above where the LCD screen was located, find the viewfinder cover clip.
    • Detach the clip with a pair of tweezers.
    • Push upwards and remove the viewfinder cover.
  23. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: adım 24, 1 resimden 1.
    • Remove the viewfinder mirror by pulling up n the mirror with tweezers.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nick Oleskowicz
287 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012 üyesi
CPSU-FORTE-S12S15G13
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 3,181
