1. Using your spudger or metal tweezers, work the rubber screw covers out of their sockets, found on each of the four corners of the back cover. Have patience! These are held in with glue and can take time and a few attempts to remove. Using a PH00 screwdriver, remove the 5.8mm screws found beneath each rubber cover (4 total).
    • Using your spudger or metal tweezers, work the rubber screw covers out of their sockets, found on each of the four corners of the back cover.
    • Have patience! These are held in with glue and can take time and a few attempts to remove.
    • Using a PH00 screwdriver, remove the 5.8mm screws found beneath each rubber cover (4 total).
  2. Using the flat end of your prying tool, work the back cover away from the rest of the gTabet. Starting near the charging port, work in one direction around the perimeter of the device. Do not insert prying tool deeper than is necessary to separate back cover. You may damage other components!
    • Using the flat end of your prying tool, work the back cover away from the rest of the gTabet.
    • Starting near the charging port, work in one direction around the perimeter of the device.
    • Do not insert prying tool deeper than is necessary to separate back cover. You may damage other components!
    • Lift off back cover to reveal the interior of the device.
  3. The battery is the large black square that dominates much of the device interior. There is tape holding several wires in place. This must be removed before the battery can be removed. Peel it gently; you will want to use it later. There is tape holding several wires in place. This must be removed before the battery can be removed. Peel it gently; you will want to use it later.
    • The battery is the large black square that dominates much of the device interior.
    • There is tape holding several wires in place. This must be removed before the battery can be removed. Peel it gently; you will want to use it later.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Using a PLASTIC tool of your choice, push both ends of the power cable connector, one at a time, away from its housing. This will slowly wiggle the connector out of place. The white connector(red markup) comes off while the off white connector(orange markup) stays on the motherboard. The white connector(red markup) comes off while the off white connector(orange markup) stays on the motherboard.
    • Using a PLASTIC tool of your choice, push both ends of the power cable connector, one at a time, away from its housing. This will slowly wiggle the connector out of place.
    • The white connector(red markup) comes off while the off white connector(orange markup) stays on the motherboard.
  6. Using tweezers, remove the protective foam backing arch from the front-facing camera. Pull the camera out of its housing and move it aside. Be sure to move any wires out of the way before attempting to move the battery, as these are still connected and shouldn't be stressed!
    • Using tweezers, remove the protective foam backing arch from the front-facing camera.
    • Pull the camera out of its housing and move it aside.
    • Be sure to move any wires out of the way before attempting to move the battery, as these are still connected and shouldn't be stressed!
    • Gently lift the battery up and away from the rest of the device and set it aside.
  7. Using tweezers or the spudger-wiggle technique, disconnect the two wires (shown here to the right of the battery power cable housing) from their housings. It is very easy to damage the wires going to and from these connectors! Going slow and using as little force as possible will help to prevent this. It is very easy to damage the wires going to and from these connectors! Going slow and using as little force as possible will help to prevent this.
    • Using tweezers or the spudger-wiggle technique, disconnect the two wires (shown here to the right of the battery power cable housing) from their housings.
    • It is very easy to damage the wires going to and from these connectors! Going slow and using as little force as possible will help to prevent this.
  8. Find the antenna receiver affixed to the LCD Screen chassis with foil tape.  Gently peel back the foil tape and remove the antenna. Now follow the wire attached to the antenna back to where it connects to the motherboard.  Gently rotate and lift the connection until it lifts away. You may now install a replacement antenna by reversing these steps.
    • Find the antenna receiver affixed to the LCD Screen chassis with foil tape. Gently peel back the foil tape and remove the antenna.
    • Now follow the wire attached to the antenna back to where it connects to the motherboard. Gently rotate and lift the connection until it lifts away.
    • You may now install a replacement antenna by reversing these steps.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cristian
582 İtibar
5 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 4-1, Miles Fall 2014 UMass Dartmouth, Team 4-1, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 2
Her zaman: 151
