Ana içeriğe geç
Viewsonic gTablet UPC300-2.2 Battery Replacement
Neye ihtiyacın var
  1. Viewsonic gTablet UPC300-2.2 Battery Replacement, Back Cover Screws: adım 1, 3 resimden 1. Viewsonic gTablet UPC300-2.2 Battery Replacement, Back Cover Screws: adım 1, 3 resimden 2. Viewsonic gTablet UPC300-2.2 Battery Replacement, Back Cover Screws: adım 1, 3 resimden 3.
    • Using your spudger or metal tweezers, work the rubber screw covers out of their sockets, found on each of the four corners of the back cover.
    • Have patience! These are held in with glue and can take time and a few attempts to remove.
    • Using a PH00 screwdriver, remove the 5.8mm screws found beneath each rubber cover (4 total).
  2. Viewsonic gTablet UPC300-2.2 Battery Replacement, Pry Off Back Cover: adım 2, 3 resimden 1. Viewsonic gTablet UPC300-2.2 Battery Replacement, Pry Off Back Cover: adım 2, 3 resimden 2. Viewsonic gTablet UPC300-2.2 Battery Replacement, Pry Off Back Cover: adım 2, 3 resimden 3.
    • Using the flat end of your prying tool, work the back cover away from the rest of the gTabet.
    • Starting near the charging port, work in one direction around the perimeter of the device.
    • Do not insert prying tool deeper than is necessary to separate back cover. You may damage other components!
    • Lift off back cover to reveal the interior of the device.
  3. Viewsonic gTablet UPC300-2.2 Battery Replacement, Identify Battery & Prepare for Removal: adım 3, 3 resimden 1. Viewsonic gTablet UPC300-2.2 Battery Replacement, Identify Battery & Prepare for Removal: adım 3, 3 resimden 2. Viewsonic gTablet UPC300-2.2 Battery Replacement, Identify Battery & Prepare for Removal: adım 3, 3 resimden 3.
    • The battery is the large black square that dominates much of the device interior.
    • There is tape holding several wires in place. This must be removed before the battery can be removed. Peel it gently; you will want to use it later.
  4. Viewsonic gTablet UPC300-2.2 Battery Replacement, Disconnect Battery Power Cable: adım 4, 3 resimden 1. Viewsonic gTablet UPC300-2.2 Battery Replacement, Disconnect Battery Power Cable: adım 4, 3 resimden 2. Viewsonic gTablet UPC300-2.2 Battery Replacement, Disconnect Battery Power Cable: adım 4, 3 resimden 3.
    • Using a PLASTIC tool of your choice, push both ends of the power cable connector, one at a time, away from its housing. This will slowly wiggle the connector out of place.
    • The white connector(red markup) comes off while the off white connector(orange markup) stays on the motherboard.
  5. Viewsonic gTablet UPC300-2.2 Battery Replacement, Move Front-Facing Camera & Remove Battery: adım 5, 3 resimden 1. Viewsonic gTablet UPC300-2.2 Battery Replacement, Move Front-Facing Camera & Remove Battery: adım 5, 3 resimden 2. Viewsonic gTablet UPC300-2.2 Battery Replacement, Move Front-Facing Camera & Remove Battery: adım 5, 3 resimden 3.
    • Using tweezers, remove the protective foam backing arch from the front-facing camera.
    • Pull the camera out of its housing and move it aside.
    • Be sure to move any wires out of the way before attempting to move the battery, as these are still connected and shouldn't be stressed!
    • Gently lift the battery up and away from the rest of the device and set it aside.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cristian
591 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Miles Fall 2014 UMass Dartmouth, Team 4-1, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,578
