Ana içeriğe geç
Vinotemp VT-12TEDi Power Cord Replacement
Neye ihtiyacın var
  1. Vinotemp VT-12TEDi Power Cord Replacement, Power Cord: adım 1, 2 resimden 1. Vinotemp VT-12TEDi Power Cord Replacement, Power Cord: adım 1, 2 resimden 2.
    • Remove nine 12mm Phillips screws from the upper back panel.
    • Remove three 12mm Phillips screws inset under the back panel.
    • As soon as the screws are removed, the panel will fall freely.
    • When replacing the twelve 12mm Phillips screws, do not tighten the fasteners until all twelve screws have been loosely fitted back onto the cooler. This will ensure the flimsy metal casing will not warp.
  2. Vinotemp VT-12TEDi Power Cord Replacement: adım 2, 1 resimden 1.
    • Power Cord Fastener
    • Ground
    • Motherboard
    • Heat Sink Fan
    • Heat Sink
  3. Vinotemp VT-12TEDi Power Cord Replacement: adım 3, 3 resimden 1. Vinotemp VT-12TEDi Power Cord Replacement: adım 3, 3 resimden 2. Vinotemp VT-12TEDi Power Cord Replacement: adım 3, 3 resimden 3.
    • Remove two 7mm Hex Nuts.
    • Clearance is minimal and these screws are very tight. You will likely need a socket wrench to avoid stripping.
    • If the white plastic components stick, pry them apart with a metal spudger. Don't pull on the power cord to get plastic pieces to separate.
  4. Vinotemp VT-12TEDi Power Cord Replacement: adım 4, 2 resimden 1. Vinotemp VT-12TEDi Power Cord Replacement: adım 4, 2 resimden 2.
    • Remove one 12mm Phillips screw securing ground.
  5. Vinotemp VT-12TEDi Power Cord Replacement: adım 5, 3 resimden 1. Vinotemp VT-12TEDi Power Cord Replacement: adım 5, 3 resimden 2. Vinotemp VT-12TEDi Power Cord Replacement: adım 5, 3 resimden 3.
    • Remove power cable from motherboard.
    • Pinch cable connector to release it from the motherboard, then pull.
  6. Vinotemp VT-12TEDi Power Cord Replacement: adım 6, 1 resimden 1.
    • Your power cord is removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeff Snyder
8.802 İtibar
4 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 845
