Ana içeriğe geç
Visual Land Prestige 10 Back Case Replacement
Neye ihtiyacın var
  1. Visual Land Prestige 10 Back Case Replacement, Back Case: adım 1, 3 resimden 1. Visual Land Prestige 10 Back Case Replacement, Back Case: adım 1, 3 resimden 2. Visual Land Prestige 10 Back Case Replacement, Back Case: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Back Case Replacement: adım 2, 3 resimden 1. Visual Land Prestige 10 Back Case Replacement: adım 2, 3 resimden 2. Visual Land Prestige 10 Back Case Replacement: adım 2, 3 resimden 3.
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Back Case Replacement: adım 3, 3 resimden 1. Visual Land Prestige 10 Back Case Replacement: adım 3, 3 resimden 2. Visual Land Prestige 10 Back Case Replacement: adım 3, 3 resimden 3.
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Back Case Replacement: adım 4, 2 resimden 1. Visual Land Prestige 10 Back Case Replacement: adım 4, 2 resimden 2.
    • Gently remove the speakers from the back case with tweezers and set the case aside.
Sonuç
Bir Yorum
Ok but where to I go to buy the replacement for the screen? This is directing us to take apart and reassemble the tablet, but not where to buy or get a new screen.
Jordyn Glenn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,327
