Ana içeriğe geç
Visual Land Prestige 10 Battery Replacement
Neye ihtiyacın var
  1. Visual Land Prestige 10 Battery Replacement, Back Case: adım 1, 3 resimden 1. Visual Land Prestige 10 Battery Replacement, Back Case: adım 1, 3 resimden 2. Visual Land Prestige 10 Battery Replacement, Back Case: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Battery Replacement: adım 2, 3 resimden 1. Visual Land Prestige 10 Battery Replacement: adım 2, 3 resimden 2. Visual Land Prestige 10 Battery Replacement: adım 2, 3 resimden 3.
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Battery Replacement: adım 3, 3 resimden 1. Visual Land Prestige 10 Battery Replacement: adım 3, 3 resimden 2. Visual Land Prestige 10 Battery Replacement: adım 3, 3 resimden 3.
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Battery Replacement: adım 4, 2 resimden 1. Visual Land Prestige 10 Battery Replacement: adım 4, 2 resimden 2.
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Battery Replacement, Battery: adım 5, 3 resimden 1. Visual Land Prestige 10 Battery Replacement, Battery: adım 5, 3 resimden 2. Visual Land Prestige 10 Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Remove yellow tape from surrounding components.
  6. Visual Land Prestige 10 Battery Replacement: adım 6, 3 resimden 1. Visual Land Prestige 10 Battery Replacement: adım 6, 3 resimden 2. Visual Land Prestige 10 Battery Replacement: adım 6, 3 resimden 3.
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Visual Land Prestige 10 Battery Replacement: adım 7, 1 resimden 1.
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Wat if the charge port how do u replace it Visaul land 10.1
jessiepettway - Yanıt
Thank you for posting. Great illustrations. Got mine apart so easy.
Lori Pepper - Yanıt
where can I get a replacement battery for Visual Land Prestige 10D tablet?
John Conger - Yanıt
Where can I get a replacement battery for Visual Land Prestige 10.1 tablet???
Thank you.
Belinda Rivera
brp52@hotmail.com
Belinda Lorenzana - Yanıt
where can I get a replacement battery for visionland prestige 10 3.7v
Fred Maxwell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 8,301
