Ana içeriğe geç
Visual Land Prestige 10 Digitizer Replacement
Neye ihtiyacın var
    1. Visual Land Prestige 10 Digitizer Replacement, Back Case: adım 1, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement, Back Case: adım 1, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement, Back Case: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      Magnetic Project Mat
      $19.95
      • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
      • All screws throughout this guide are the same 3mm size.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige 10 Digitizer Replacement: adım 2, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 2, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement: adım 2, 3 resimden 3.
      • Using the spudger, create a small opening to be used to open the back case.
      • While holding the case open, insert the plastic opening tool to get a larger opening.
      • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
      FixBot'a Sor
      Yorum Ekle
    3. Visual Land Prestige 10 Digitizer Replacement: adım 3, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 3, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement: adım 3, 3 resimden 3.
      • now that the case is open, carefully remove the speakers and set aside.
      FixBot'a Sor
      Yorum Ekle
    4. Visual Land Prestige 10 Digitizer Replacement: adım 4, 2 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 4, 2 resimden 2.
      • Gently remove the speakers from the back case with tweezers and set the case aside.
      FixBot'a Sor
      Yorum Ekle
    1. Visual Land Prestige 10 Digitizer Replacement, Battery: adım 5, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement, Battery: adım 5, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement, Battery: adım 5, 3 resimden 3.
      • Remove yellow tape from surrounding components.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige 10 Digitizer Replacement: adım 6, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 6, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement: adım 6, 3 resimden 3.
      • insert the spudger and gently work around and underneath the battery.
      • With the battery separated from the LCD Display, set it aside.
      • The battery is held down by very strong adhesive.
      FixBot'a Sor
      Yorum Ekle
    3. Visual Land Prestige 10 Digitizer Replacement: adım 7, 1 resimden 1.
      • Desolder and remove the 2 wires from the motherboard.
      • Use caution when desoldering to avoid damage to yourself or to the components.
      FixBot'a Sor
      Yorum Ekle
    1. Visual Land Prestige 10 Digitizer Replacement, Front Facing Camera: adım 8, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement, Front Facing Camera: adım 8, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement, Front Facing Camera: adım 8, 3 resimden 3.
      • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
      • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
      • Gently grip and pull up the front camera, covered by protective adhesive foam.
      • Set aside the Camera housing.
      FixBot'a Sor
      Yorum Ekle
    1. Visual Land Prestige 10 Digitizer Replacement, Motherboard: adım 9, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement, Motherboard: adım 9, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement, Motherboard: adım 9, 3 resimden 3.
      • Locate the LCD Connector.
      • Using tweezers, grip the small black tab connected to the white plastic.
      • Gently lift the tab towards you until it clicks.
      • Remove the connector by pulling straight out, gripping the black connector head.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige 10 Digitizer Replacement: adım 10, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 10, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement: adım 10, 3 resimden 3.
      • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
      • Lift the tab towards you until you feel an audible click.
      • Gently remove the connector by pulling straight out, gripping the black connector head.
      FixBot'a Sor
      Yorum Ekle
    3. Visual Land Prestige 10 Digitizer Replacement: adım 11, 2 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 11, 2 resimden 2.
      • Gently lift up the WiFi antenna and set aside.
      FixBot'a Sor
      Yorum Ekle
    4. Visual Land Prestige 10 Digitizer Replacement: adım 12, 2 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 12, 2 resimden 2.
      • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
      • Gently lift up on the controller and leave it hanging loose.
      FixBot'a Sor
      Yorum Ekle
    5. Visual Land Prestige 10 Digitizer Replacement: adım 13, 2 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 13, 2 resimden 2.
      • Remove screws located on motherboard.
      • Place on magnetic mat and label them
      • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
      FixBot'a Sor
      Yorum Ekle
    1. Visual Land Prestige 10 Digitizer Replacement, LCD Display: adım 14, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement, LCD Display: adım 14, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement, LCD Display: adım 14, 3 resimden 3.
      • Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them.
      • Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers.
      • Set aside the LCD Assembly.
      • The LCD display and backlight are separated from one another. Be sure to remember how they are aligned when putting the device back together.
      FixBot'a Sor
      Yorum Ekle
    1. Visual Land Prestige 10 Digitizer Replacement, Digitizer: adım 15, 1 resimden 1.
      • Simply lift up the loose metal frame and set aside.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige 10 Digitizer Replacement: adım 16, 3 resimden 1. Visual Land Prestige 10 Digitizer Replacement: adım 16, 3 resimden 2. Visual Land Prestige 10 Digitizer Replacement: adım 16, 3 resimden 3.
      • Be extremely careful removing the touchscreen, avoiding sharp glass and hot surfaces.
      • Using the heating pad, heat the edges of the touchscreen to loosen the adhesive.
      • using the spudger, slowly and gently work around the edges, removing the touchscreen.
      • The Tablet we used came with a shattered screen, making this step much more difficult.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Great write up, but have a question . Could you heat up the adhesive for the digitizer like an iPad and remove it without taking everything apart?
Michael - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 2,828
