Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
  1. Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from. All screws throughout this guide are the same 3mm size. All screws throughout this guide are the same 3mm size.
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Using the spudger, create a small opening to be used to open the back case. While holding the case open, insert the plastic opening tool to get a larger opening. Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. now that the case is open, carefully remove the speakers and set aside. now that the case is open, carefully remove the speakers and set aside. now that the case is open, carefully remove the speakers and set aside.
    • now that the case is open, carefully remove the speakers and set aside.
  5. Gently remove the speakers from the back case with tweezers and set the case aside. Gently remove the speakers from the back case with tweezers and set the case aside.
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  6. Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click. Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible. Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
Sonuç
Connor Reese
1.156 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 188
