Neye ihtiyacın var
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
Gently grip and pull up the front camera, covered by protective adhesive foam.
Set aside the Camera housing.
Locate the LCD Connector.
Using tweezers, grip the small black tab connected to the white plastic.
Gently lift the tab towards you until it clicks.
Remove the connector by pulling straight out, gripping the black connector head.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I just received my tablet. and it will not allow me to set up a password. It keeps asking for previous password. I have done a hard reset but have not been able to set up my tablet.
