Ana içeriğe geç
Visual Land Prestige 7G Backlight Replacement
Neye ihtiyacın var
  1. Visual Land Prestige 7G Backlight Replacement, Backplate: adım 1, 2 resimden 1. Visual Land Prestige 7G Backlight Replacement, Backplate: adım 1, 2 resimden 2.
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
    FixBot'a Sor
    Yorum Ekle
  2. Visual Land Prestige 7G Backlight Replacement: adım 2, 1 resimden 1.
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Visual Land Prestige 7G Backlight Replacement: adım 3, 2 resimden 1. Visual Land Prestige 7G Backlight Replacement: adım 3, 2 resimden 2.
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
    FixBot'a Sor
    Yorum Ekle
  4. Visual Land Prestige 7G Backlight Replacement, Motherboard: adım 4, 3 resimden 1. Visual Land Prestige 7G Backlight Replacement, Motherboard: adım 4, 3 resimden 2. Visual Land Prestige 7G Backlight Replacement, Motherboard: adım 4, 3 resimden 3.
    • Lay the device on its back.
    • Flip up the black locking flap then remove the ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  5. Visual Land Prestige 7G Backlight Replacement: adım 5, 3 resimden 1. Visual Land Prestige 7G Backlight Replacement: adım 5, 3 resimden 2. Visual Land Prestige 7G Backlight Replacement: adım 5, 3 resimden 3.
    • Connected to the motherboard there will be a red, black, and grey wire.
    • Use a soldering iron to melt the soldered contact points.
    • Disconnect the wires.
    • Lift the motherboard up and out of the chassis.
    • The high temperatures of a soldering gun and melted solder may create the potential for burns. Inhaling the fumes in an enclosed environment may also lead to irritation and desensitization of the eyes and respiratory tract.
    FixBot'a Sor
    Yorum Ekle
  6. Visual Land Prestige 7G Backlight Replacement, Backlight: adım 6, 1 resimden 1.
    • Remove the four screws with a Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Visual Land Prestige 7G Backlight Replacement: adım 7, 2 resimden 1. Visual Land Prestige 7G Backlight Replacement: adım 7, 2 resimden 2.
    • Use an opening tool to lift the backplate out of the case.
    • Pay close attention to the black tabs holding it in, making sure not to break them.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 264
