Ana içeriğe geç
Visual Land Prestige 7G Speaker Replacement
Neye ihtiyacın var
  1. Visual Land Prestige 7G Speaker Replacement, Backplate: adım 1, 2 resimden 1. Visual Land Prestige 7G Speaker Replacement, Backplate: adım 1, 2 resimden 2.
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Speaker Replacement: adım 2, 1 resimden 1.
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Speaker Replacement: adım 3, 2 resimden 1. Visual Land Prestige 7G Speaker Replacement: adım 3, 2 resimden 2.
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Speaker Replacement, Speaker: adım 4, 2 resimden 1. Visual Land Prestige 7G Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Take the soldering gun and place it on the black and red wires to melt the soldered conncetions.
    • Remove the speaker.
Sonuç
Brandon Gray
207 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 36
