Giriş
This guide is useful for replacing the rear case, but it's also the first steps necessary to take apart the device if you want to replace any other components inside. If you're looking to fix any hardware-based problems on your device, start here.
Neye ihtiyacın var
Remove the two 8mm Phillips Head screws located at the bottom of your device.
Bir başkası bu kılavuzu tamamladı.
