Ana içeriğe geç
Visual Land Prestige 7L Back Panel Replacement
Neye ihtiyacın var
    1. Visual Land Prestige 7L Back Panel Replacement, Back Panel: adım 1, 2 resimden 1. Visual Land Prestige 7L Back Panel Replacement, Back Panel: adım 1, 2 resimden 2.
      • Remove the two 8mm Phillips Head screws located at the bottom of your device.
      FixBot'a Sor
      Yorum Ekle
    2. Visual Land Prestige 7L Back Panel Replacement: adım 2, 3 resimden 1. Visual Land Prestige 7L Back Panel Replacement: adım 2, 3 resimden 2. Visual Land Prestige 7L Back Panel Replacement: adım 2, 3 resimden 3.
      • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
      • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
      • Finish unsnapping each plastic piece holding the device together along the bottom.
      FixBot'a Sor
      Yorum Ekle
    3. Visual Land Prestige 7L Back Panel Replacement: adım 3, 3 resimden 1. Visual Land Prestige 7L Back Panel Replacement: adım 3, 3 resimden 2. Visual Land Prestige 7L Back Panel Replacement: adım 3, 3 resimden 3.
      • Move the spudger down the rest of the case, separating each side, and finally the top.
      • Pull the back off and place it to the side.
      • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert
141 İtibar
1 Kılavuz yazıldı
Ekip
Penn State, Team 2-25, Kaschak Winter 2015 Penn State, Team 2-25, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S2G25
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 723
