Ana içeriğe geç
Visual Land Prestige 7L Screen Replacement
Neye ihtiyacın var
  1. Visual Land Prestige 7L Screen Replacement, Back Panel: adım 1, 2 resimden 1. Visual Land Prestige 7L Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Screen Replacement: adım 2, 3 resimden 1. Visual Land Prestige 7L Screen Replacement: adım 2, 3 resimden 2. Visual Land Prestige 7L Screen Replacement: adım 2, 3 resimden 3.
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Screen Replacement: adım 3, 3 resimden 1. Visual Land Prestige 7L Screen Replacement: adım 3, 3 resimden 2. Visual Land Prestige 7L Screen Replacement: adım 3, 3 resimden 3.
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Screen Replacement, Screen: adım 4, 3 resimden 1. Visual Land Prestige 7L Screen Replacement, Screen: adım 4, 3 resimden 2. Visual Land Prestige 7L Screen Replacement, Screen: adım 4, 3 resimden 3.
    • Remove the tape holding the motherboard, wires, and connecters in place.
  5. Visual Land Prestige 7L Screen Replacement: adım 5, 3 resimden 1. Visual Land Prestige 7L Screen Replacement: adım 5, 3 resimden 2. Visual Land Prestige 7L Screen Replacement: adım 5, 3 resimden 3.
    • Unclip the three connectors by gently pulling the rear panel up and away from the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Pull out each of the gold connections.
    • The gold connections will disconnect from the motherboard, but not entirely from the device. Let them sit loosely where they are attached and be careful not to tear them when working in their proximity on the device.
  6. Visual Land Prestige 7L Screen Replacement: adım 6, 1 resimden 1.
    • Remove the seven 4mm Phillips Head screws that hold the touchscreen panel and motherboard together.
  7. Visual Land Prestige 7L Screen Replacement: adım 7, 3 resimden 1. Visual Land Prestige 7L Screen Replacement: adım 7, 3 resimden 2. Visual Land Prestige 7L Screen Replacement: adım 7, 3 resimden 3.
    • Gently flip over the motherboard and begin to use the spudger to pry away the touchscreen panel from the front screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Zach
486 İtibar
2 adet Kılavuz yazıldı
Ekip
Penn State, Team 2-25, Kaschak Winter 2015 Penn State, Team 2-25, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S2G25
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Muchas gracias por tan importante aporte a la comunidad; desde Colombia  con respeto. Atte. GAZUTEC
GAZUTEC - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 653
