Ana içeriğe geç
Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement
Neye ihtiyacın var
  1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: adım 1, 2 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: adım 1, 2 resimden 2.
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 2, 2 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 2, 2 resimden 2.
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
    FixBot'a Sor
    Yorum Ekle
  3. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 3, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 3, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 3, 3 resimden 3.
    • Wedge a curved metal spudger under the speaker in order to remove it.
    • The speaker is held in place by an adhesive and can be difficult to remove.
    FixBot'a Sor
    Yorum Ekle
  4. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 4, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 4, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
    FixBot'a Sor
    Yorum Ekle
  5. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 5, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 5, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to lift the black tab.
    FixBot'a Sor
    Yorum Ekle
  6. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 6, 2 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 6, 2 resimden 2.
    • Carefully lift and remove the ribbon cable from the black tab.
    FixBot'a Sor
    Yorum Ekle
  7. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 7, 2 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 7, 2 resimden 2.
    • Use a plastic opening tool to remove the camera.
    FixBot'a Sor
    Yorum Ekle
  8. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 8, 2 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
    FixBot'a Sor
    Yorum Ekle
  9. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 9, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 9, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 9, 3 resimden 3.
    • Lift the tape holding down the battery.
    FixBot'a Sor
    Yorum Ekle
  10. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 10, 2 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    FixBot'a Sor
    Yorum Ekle
  11. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 11, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 11, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 11, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  12. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 12, 2 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 12, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  13. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 13, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 13, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 13, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  14. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 14, 1 resimden 1.
    • Safely remove the battery and motherboard from the tablet.
    FixBot'a Sor
    Yorum Ekle
  15. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 15, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 15, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 15, 3 resimden 3.
    • Lift the tape on the sides.
    FixBot'a Sor
    Yorum Ekle
  16. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 16, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 16, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 16, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
    FixBot'a Sor
    Yorum Ekle
  17. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 17, 3 resimden 1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 17, 3 resimden 2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 17, 3 resimden 3.
    • Wedge a metal spudger underneath the LCD screen to remove it.
    FixBot'a Sor
    Yorum Ekle
  18. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: adım 18, 1 resimden 1.
    • Replace the front screen to replace the digitizer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Sabrina Scholten
621 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-1, Oliver Fall 2016 UC Davis, Team 2-1, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G1
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 765
