Ana içeriğe geç
Visual Land Prestige Elite 7Q LCD Screen Replacement
Neye ihtiyacın var
  1. Visual Land Prestige Elite 7Q LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 2, 2 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 2, 2 resimden 2.
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 3, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 3, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 3, 3 resimden 3.
    • Wedge a curved metal spudger to remove the speaker.
  4. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 4, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 4, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 4, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
  5. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 5, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 5, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to lift the black tab.
  6. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 6, 2 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 6, 2 resimden 2.
    • Carefully remove the ribbon cable from the black tab.
  7. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 7, 2 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 7, 2 resimden 2.
    • Use a plastic opening tool to remove the camera.
  8. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 8, 2 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
  9. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 9, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 9, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 9, 3 resimden 3.
    • Lift the tape holding down the battery.
  10. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 10, 2 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
  11. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 11, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 11, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 11, 3 resimden 3.
  12. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 12, 2 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 12, 2 resimden 2.
  13. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 13, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 13, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 13, 3 resimden 3.
  14. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 14, 1 resimden 1.
    • Lift to remove the battery and motherboard from the tablet.
  15. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 15, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 15, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 15, 3 resimden 3.
    • Lift the tape on the sides.
  16. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 16, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 16, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 16, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
  17. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 17, 3 resimden 1. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 17, 3 resimden 2. Visual Land Prestige Elite 7Q LCD Screen Replacement: adım 17, 3 resimden 3.
    • Be careful on this step - the screen is fragile and can break easily.
    • Wedge a metal spudger underneath the LCD to remove it.
    • Replace the LCD.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sabrina Scholten
621 İtibar
6 adet Kılavuz yazıldı
Ekip
UC Davis, Team 2-1, Oliver Fall 2016 UC Davis, Team 2-1, Oliver Fall 2016 üyesi
UCD-OLIVER-F16S2G1
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 356
