Ana içeriğe geç
Visual Land Prestige Pro 7D Back Panel Replacement
Neye ihtiyacın var
  1. Visual Land Prestige Pro 7D Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Back Panel Replacement: adım 2, 1 resimden 1.
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Max Hudson
422 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G41
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,673
