Ana içeriğe geç
Visual Land Prestige Pro 7D Camera Replacement
Neye ihtiyacın var
  1. Visual Land Prestige Pro 7D Camera Replacement, Back Panel: adım 1, 1 resimden 1.
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Visual Land Prestige Pro 7D Camera Replacement: adım 2, 1 resimden 1.
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
    FixBot'a Sor
    Yorum Ekle
  3. Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: adım 3, 2 resimden 1. Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: adım 3, 2 resimden 2.
    • Remove the black pad on the back of the camera by peeling it off.
    FixBot'a Sor
    Yorum Ekle
  4. Visual Land Prestige Pro 7D Camera Replacement: adım 4, 1 resimden 1.
    • With the bottom of the device facing away from you, pull the camera out of its black housing.
    • The camera will come right out when you lift with your fingers.
    FixBot'a Sor
    Yorum Ekle
  5. Visual Land Prestige Pro 7D Camera Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to lift the grey connector, connecting the camera ribbon to the circuit board, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Brandon Kodama
229 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S10G41
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 712
