Ana içeriğe geç
Vivitar DVR 781HD Motherboard Replacement
Neye ihtiyacın var
  1. Vivitar DVR 781HD Motherboard Replacement, Front Case: adım 1, 3 resimden 1. Vivitar DVR 781HD Motherboard Replacement, Front Case: adım 1, 3 resimden 2. Vivitar DVR 781HD Motherboard Replacement, Front Case: adım 1, 3 resimden 3.
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Motherboard Replacement: adım 2, 1 resimden 1.
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Motherboard Replacement: adım 3, 3 resimden 1. Vivitar DVR 781HD Motherboard Replacement: adım 3, 3 resimden 2. Vivitar DVR 781HD Motherboard Replacement: adım 3, 3 resimden 3.
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Vivitar DVR 781HD Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently lift the motherboard, handling it by the edges.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan McDaniel
592 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S54G6
3 Üyeler
10 adet Kılavuz yazıldı
3 Yorum
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - Yanıt
How do you get a motherboard?
Rdam Russell - Yanıt
Where do we get one?
bikerbarbie29 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,444
