Ana içeriğe geç
Vivitar DVR 781HD Screen Replacement
Neye ihtiyacın var
  1. Vivitar DVR 781HD Screen Replacement, Front Case: adım 1, 3 resimden 1. Vivitar DVR 781HD Screen Replacement, Front Case: adım 1, 3 resimden 2. Vivitar DVR 781HD Screen Replacement, Front Case: adım 1, 3 resimden 3.
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
    FixBot'a Sor
    Yorum Ekle
  2. Vivitar DVR 781HD Screen Replacement: adım 2, 1 resimden 1.
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
    FixBot'a Sor
    Yorum Ekle
  3. Vivitar DVR 781HD Screen Replacement: adım 3, 3 resimden 1. Vivitar DVR 781HD Screen Replacement: adım 3, 3 resimden 2. Vivitar DVR 781HD Screen Replacement: adım 3, 3 resimden 3.
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Vivitar DVR 781HD Screen Replacement, Motherboard: adım 4, 2 resimden 1. Vivitar DVR 781HD Screen Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
    FixBot'a Sor
    Yorum Ekle
  5. Vivitar DVR 781HD Screen Replacement: adım 5, 1 resimden 1.
    • Gently lift the motherboard, handling it by the edges.
    FixBot'a Sor
    Yorum Ekle
  6. Vivitar DVR 781HD Screen Replacement, Screen: adım 6, 2 resimden 1. Vivitar DVR 781HD Screen Replacement, Screen: adım 6, 2 resimden 2.
    • Remove the two 4mm Phillips #1 screws holding the screen assembly to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Vivitar DVR 781HD Screen Replacement: adım 7, 2 resimden 1. Vivitar DVR 781HD Screen Replacement: adım 7, 2 resimden 2.
    • Turn the motherboard and screen over.
    • Gently lift the screen from the motherboard, handling it by the edges of the black plastic holder.
    FixBot'a Sor
    Yorum Ekle
  8. Vivitar DVR 781HD Screen Replacement: adım 8, 1 resimden 1.
    • Using a soldering iron, melt the solder connection between the screen's ribbon cable and the motherboard. Pull the ribbon cable away before the solder solidifies.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nathan McDaniel
592 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016 üyesi
IUPUI-WILSON-S16S54G6
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 40
Her zaman: 955
