Ana içeriğe geç
Vivitar Vivicam T027 Screen Replacement
Neye ihtiyacın var
  1. Vivitar Vivicam T027 Screen Replacement, Screen: adım 1, 2 resimden 1. Vivitar Vivicam T027 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
  2. Vivitar Vivicam T027 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
  3. Vivitar Vivicam T027 Screen Replacement: adım 3, 2 resimden 1. Vivitar Vivicam T027 Screen Replacement: adım 3, 2 resimden 2.
    • Separate the front piece of the camera from the back to reveal the motherboard.
  4. Vivitar Vivicam T027 Screen Replacement: adım 4, 1 resimden 1.
    • Remove the plastic silver strip from the front case of the camera.
  5. Vivitar Vivicam T027 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
  6. Vivitar Vivicam T027 Screen Replacement: adım 6, 1 resimden 1.
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Vivitar Vivicam T027 Screen Replacement: adım 7, 2 resimden 1. Vivitar Vivicam T027 Screen Replacement: adım 7, 2 resimden 2.
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicole Knoebel
258 İtibar
2 adet Kılavuz yazıldı
Ekip
Marist, Team 15-13, Laflen Spring 2015 Marist, Team 15-13, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S15G13
4 Üyeler
3 adet Kılavuz yazıldı
2 Yorum
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Yanıt
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 844
