Ana içeriğe geç
Vivitar XO 7 Motherboard Replacement
Neye ihtiyacın var
  1. Vivitar XO 7 Motherboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Remove the two 3mm Phillips #00 screws on the bottom of the tablet.
  2. Vivitar XO 7 Motherboard Replacement: adım 2, 1 resimden 1.
    • With the plastic opening tools, pry open the back cover.
  3. Vivitar XO 7 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the back cover from the tablet.
  4. Vivitar XO 7 Motherboard Replacement, Battery: adım 4, 2 resimden 1. Vivitar XO 7 Motherboard Replacement, Battery: adım 4, 2 resimden 2.
    • Peel off the black pieces of tape from the internal components.
  5. Vivitar XO 7 Motherboard Replacement: adım 5, 2 resimden 1. Vivitar XO 7 Motherboard Replacement: adım 5, 2 resimden 2.
    • Carefully remove the battery from the tablet.
  6. Vivitar XO 7 Motherboard Replacement: adım 6, 2 resimden 1. Vivitar XO 7 Motherboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
  7. Vivitar XO 7 Motherboard Replacement, Speaker: adım 7, 1 resimden 1.
    • Carefully remove the speaker from the metal plate with your hands.
  8. Vivitar XO 7 Motherboard Replacement: adım 8, 2 resimden 1. Vivitar XO 7 Motherboard Replacement: adım 8, 2 resimden 2.
    Satın Al
    • With tweezers, firmly grab the wire at the base and pull to disconnect the speaker from the motherboard.
  9. Vivitar XO 7 Motherboard Replacement, Camera: adım 9, 1 resimden 1.
    • Peel off black tape that is holding the camera in place.
  10. Vivitar XO 7 Motherboard Replacement: adım 10, 1 resimden 1.
    • Carefully disconnect the ribbon cables from the motherboard.
  11. Vivitar XO 7 Motherboard Replacement: adım 11, 2 resimden 1. Vivitar XO 7 Motherboard Replacement: adım 11, 2 resimden 2.
    Satın Al
    • Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
  12. Vivitar XO 7 Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Disconnect the large golden ribbon cable that is connected to the digitizer. Firmly grab the cable close to the connection and pull to disconnect.
  13. Vivitar XO 7 Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove four 4mm PH00 silver screws from the motherboard.
  14. Vivitar XO 7 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove two 2mm PH00 black screws from the motherboard.
  15. Vivitar XO 7 Motherboard Replacement: adım 15, 1 resimden 1.
    • Carefully remove the silver cover from the motherboard.
  16. Vivitar XO 7 Motherboard Replacement: adım 16, 2 resimden 1. Vivitar XO 7 Motherboard Replacement: adım 16, 2 resimden 2.
    • Gently pick up and turn over the motherboard. While turned over, disconnect the last ribbon cable that connects to screen.
Sonuç
James Lunn
116 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Winter 2015 USF Tampa, Team 11-1, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 938
