Ana içeriğe geç
Vivotek FD8169 Motherboard Replacement
Neye ihtiyacın var
  1. Vivotek FD8169 Motherboard Replacement, Dome Cover: adım 1, 1 resimden 1.
    • Loosen the outside screw.
  2. Vivotek FD8169 Motherboard Replacement: adım 2, 1 resimden 1.
    • Press down on the side button, and lift up the top dome.
  3. Vivotek FD8169 Motherboard Replacement, Camera Module: adım 3, 1 resimden 1.
    • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
  4. Vivotek FD8169 Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift off the camera base from the motherboard.
  5. Vivotek FD8169 Motherboard Replacement: adım 5, 1 resimden 1.
    • Unscrew the cord from the motherboard.
    • Unplug the remaining connection.
  6. Vivotek FD8169 Motherboard Replacement: adım 6, 1 resimden 1.
    • Unscrew the camera from the camera base with a hex screwdriver on both sides.
  7. Vivotek FD8169 Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull the camera out from the camera base.
  8. Vivotek FD8169 Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
  9. Vivotek FD8169 Motherboard Replacement: adım 9, 1 resimden 1.
    • Once the screws are gone, lift the faulty motherboard and replace with a new one.
Sonuç
Artem Dudko
135 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Simcock Fall 2021 UMass Dartmouth, Team 1-6, Simcock Fall 2021 üyesi
UMASSD-SIMCOCK-F21S1G6
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 238
