Ana içeriğe geç
Vizio CT15 Keyboard Replacement
Neye ihtiyacın var
  1. Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: adım 1, 2 resimden 1. Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: adım 1, 2 resimden 2.
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Keyboard Replacement, Battery: adım 2, 1 resimden 1.
  3. Vizio CT15 Keyboard Replacement: adım 3, 2 resimden 1. Vizio CT15 Keyboard Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Keyboard Replacement, Speakers: adım 4, 2 resimden 1. Vizio CT15 Keyboard Replacement, Speakers: adım 4, 2 resimden 2.
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Keyboard Replacement: adım 5, 2 resimden 1. Vizio CT15 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Keyboard Replacement: adım 6, 3 resimden 1. Vizio CT15 Keyboard Replacement: adım 6, 3 resimden 2. Vizio CT15 Keyboard Replacement: adım 6, 3 resimden 3.
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Keyboard Replacement: adım 7, 2 resimden 1. Vizio CT15 Keyboard Replacement: adım 7, 2 resimden 2.
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
  8. Vizio CT15 Keyboard Replacement, CPU Fan: adım 8, 2 resimden 1. Vizio CT15 Keyboard Replacement, CPU Fan: adım 8, 2 resimden 2.
    • Unplug the fan from the motherboard.
  9. Vizio CT15 Keyboard Replacement: adım 9, 2 resimden 1. Vizio CT15 Keyboard Replacement: adım 9, 2 resimden 2.
    • Remove the three Phillips #0 screws.
    • Pull the fan out to remove.
  10. Vizio CT15 Keyboard Replacement, Keyboard: adım 10, 2 resimden 1. Vizio CT15 Keyboard Replacement, Keyboard: adım 10, 2 resimden 2.
    • Remove the four Philips #0 screws from the heatsink.
    • Pull up and out to remove the heatsink from the laptop.
  11. Vizio CT15 Keyboard Replacement: adım 11, 2 resimden 1. Vizio CT15 Keyboard Replacement: adım 11, 2 resimden 2.
    • Remove the eight Phillips #0 screws from the motherboard.
    • Lift the motherboard up and out to remove it from the laptop.
  12. Vizio CT15 Keyboard Replacement: adım 12, 1 resimden 1.
    • Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
  13. Vizio CT15 Keyboard Replacement: adım 13, 3 resimden 1. Vizio CT15 Keyboard Replacement: adım 13, 3 resimden 2. Vizio CT15 Keyboard Replacement: adım 13, 3 resimden 3.
    • Use a metal spudger to carefully push the keyboard out of place.
    • Carefully flip the laptop over and pull the keyboard out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 898
