Ana içeriğe geç
Vizio CT15 Speaker Replacement
Neye ihtiyacın var
  1. Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: adım 1, 2 resimden 1. Vizio CT15 Speaker Replacement, Vizio CT15 Back Panel Removal: adım 1, 2 resimden 2.
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Speaker Replacement, Battery: adım 2, 1 resimden 1.
  3. Vizio CT15 Speaker Replacement: adım 3, 2 resimden 1. Vizio CT15 Speaker Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Speaker Replacement, Speakers: adım 4, 2 resimden 1. Vizio CT15 Speaker Replacement, Speakers: adım 4, 2 resimden 2.
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Speaker Replacement: adım 5, 2 resimden 1. Vizio CT15 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Speaker Replacement: adım 6, 3 resimden 1. Vizio CT15 Speaker Replacement: adım 6, 3 resimden 2. Vizio CT15 Speaker Replacement: adım 6, 3 resimden 3.
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Speaker Replacement: adım 7, 2 resimden 1. Vizio CT15 Speaker Replacement: adım 7, 2 resimden 2.
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 391
