Ana içeriğe geç
Vizio E422VA Mainboard Replacement
Neye ihtiyacın var
  1. Vizio E422VA Mainboard Replacement, Unscrew Rear Cover: adım 1, 1 resimden 1.
    • Philips #2 screws, 15.0 mm
    • Philips #2 screws, 29.5 mm
    • Philips #2 screws, 8.0 mm
    • VESA mount points (M6, 10mm, 400mm * 200mm)
  2. Vizio E422VA Mainboard Replacement, Remove Rear Cover: adım 2, 1 resimden 1.
    • After all screws removed, the rear plastic cover can be lifted off.
  3. Vizio E422VA Mainboard Replacement, Internal View: adım 3, 1 resimden 1.
    • Mainboard
    • Power Supply / Backlight Inverter
    • Timing Control (T-Con) Board
  4. Vizio E422VA Mainboard Replacement, Remove Connectors from Mainboard (Part 1): adım 4, 1 resimden 1.
    • 4-pin connector to T-Con board. Depress plastic clip at left side and wiggle connector side to side slightly to remove.
    • 13-pin connector to Power Supply board. depress plastic clip at left edge and wiggle connector side to side. May need to pry up top/bottom edge with flat head screwdriver; alternate gradually.
    • 42-pin connector. Pry up with flat head screwdriver on left/right edges, alternating gradually.
    • Grounding clip. Using a poking tool, press at center to release catch and pull clip in indicated direction.
  5. Vizio E422VA Mainboard Replacement, Remove Connectors from Mainboard (Part 2): adım 5, 1 resimden 1.
    • 8-pin connector. Depress clip and pull connector upwards from board.
    • 10-pin connector. Depress clip and pull connector upwards from board.
    • 4-pin connector to speakers. Depress Clip and pull connector in indicated direction.
    • mounting screw. Philips #2 @ 6mm
  6. Vizio E422VA Mainboard Replacement, Removing I/O Shield on Bottom Edge (optional): adım 6, 1 resimden 1.
    • If your replacement board is missing the bottom I/O shield, you can remove the I/O shield from the old board by removing the marked screw (Philips #2).
Sonuç
MrBadAxe
121 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 42
