Giriş
This guide will help you replace the “ok” button on your Vizio t.v remote controller. The “ok” button is a key button on this controller because, without it, you won’t be able to select anything on your t.v screen. Please make sure to remove the battery before taking apart the remote.
Neye ihtiyacın var
Bu adımda kullanılan alet:iFixit Opening Tool$1.99
Use the plastic opening tool to unlock the device. Place the tool in the thin space that separates the base from the control panel.
Bir başkası bu kılavuzu tamamladı.
