Giriş
Problems with charging that cannot be resolved by using a different charger may necessitate battery replacement. Here you will find a simple, step-by-step guide to take apart the tablet on your own, and remove and replace the battery.
Neye ihtiyacın var
Hold the device in one hand with the screen facing down.
Insert the plastic opening tool under the back panel on the side of the device.
Slide the plastic opening tool down the side of the device, then repeat this process on all four sides of the device until the back panel pops off.
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Same as that guy ^^^
