Ana içeriğe geç
Vizio SmartCast Tablet Remote XR6P Power Button Replacement
Neye ihtiyacın var
  1. Vizio SmartCast Tablet Remote XR6P Power Button Replacement, Back Cover: adım 1, 1 resimden 1.
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: adım 2, 1 resimden 1.
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: adım 3, 1 resimden 1.
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Power Button Replacement, Power Button: adım 4, 1 resimden 1.
    • Using the pointy end of the black plastic spudger, carefully remove the black tape covering the plug.
  5. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: adım 5, 2 resimden 1. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: adım 5, 2 resimden 2.
    • Use the flat end of the spudger to pry the ribbon holder upwards.
  6. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Obtain the tweezers and gently pull the black ribbon until it comes out of the holder.
  7. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: adım 7, 1 resimden 1.
    • Continue pulling the black tab until you have completely removed the power button from the device.
Sonuç
1Rehber Yorum
you can perform the operation since when you shake the tablet listening that something moves in the area of ​​the power button, the tablet does not turn on by pressing the button, I have to connect the charger and now press the button and the tablet turns on, already on the device pressed power button and the menu appears shutdown and reboot, actually I don't know what the problem is.
miguel anhel Hernandez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 478
