Ana içeriğe geç
Vizio VTAB1008 Battery Replacement
Neye ihtiyacın var
  1. Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: adım 1, 2 resimden 1. Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: adım 1, 2 resimden 2.
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Battery Replacement: adım 2, 1 resimden 1.
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Battery Replacement, Battery: adım 3, 3 resimden 1. Vizio VTAB1008 Battery Replacement, Battery: adım 3, 3 resimden 2. Vizio VTAB1008 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Remove the ribbon strip that crosses the battery from both ends.
    • A blue opening tool may be used to assist.
  4. Vizio VTAB1008 Battery Replacement: adım 4, 2 resimden 1. Vizio VTAB1008 Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the connector at the top of the motherboard by pulling out and away from the motherboard.
    • This is the connector with the wires leading to the battery.
    • Tweezers may help.
  5. Vizio VTAB1008 Battery Replacement: adım 5, 3 resimden 1. Vizio VTAB1008 Battery Replacement: adım 5, 3 resimden 2. Vizio VTAB1008 Battery Replacement: adım 5, 3 resimden 3.
    • Pull the battery away from the back panel.
    • A metal spudger may be needed to pry the battery from the backing.
    • The battery is glued to the back panel and caution should be used as to not break or rupture the battery pack.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 1,370
