Ana içeriğe geç
Vizio VTAB1008 Charging Port Replacement
Neye ihtiyacın var
  1. Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: adım 1, 2 resimden 1. Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: adım 1, 2 resimden 2.
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Charging Port Replacement: adım 2, 1 resimden 1.
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Charging Port Replacement, Charging Port: adım 3, 3 resimden 1. Vizio VTAB1008 Charging Port Replacement, Charging Port: adım 3, 3 resimden 2. Vizio VTAB1008 Charging Port Replacement, Charging Port: adım 3, 3 resimden 3.
    • Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
    • 3 of the screws are clearly visible while the 4th is hidden by black tape on the upper left corner of the motherboard.
  4. Vizio VTAB1008 Charging Port Replacement: adım 4, 3 resimden 1. Vizio VTAB1008 Charging Port Replacement: adım 4, 3 resimden 2. Vizio VTAB1008 Charging Port Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove both antenna connectors with a blue opening tool/tweezers.
  5. Vizio VTAB1008 Charging Port Replacement: adım 5, 3 resimden 1. Vizio VTAB1008 Charging Port Replacement: adım 5, 3 resimden 2. Vizio VTAB1008 Charging Port Replacement: adım 5, 3 resimden 3.
    • Remove the ribbon connector at the top of the motherboard using the opening tool.
  6. Vizio VTAB1008 Charging Port Replacement: adım 6, 2 resimden 1. Vizio VTAB1008 Charging Port Replacement: adım 6, 2 resimden 2.
    • Remove the connector at the top of the motherboard by pulling the connector away from the motherboard with fingers or tweezers.
  7. Vizio VTAB1008 Charging Port Replacement: adım 7, 3 resimden 1. Vizio VTAB1008 Charging Port Replacement: adım 7, 3 resimden 2. Vizio VTAB1008 Charging Port Replacement: adım 7, 3 resimden 3.
    • Remove the connector at the side of the motherboard using the opening tool.
    • The connector is covered by a piece of black tape.
  8. Vizio VTAB1008 Charging Port Replacement: adım 8, 2 resimden 1. Vizio VTAB1008 Charging Port Replacement: adım 8, 2 resimden 2.
    • Remove the red and black wire connector from the motherboard using either fingers or tweezers.
  9. Vizio VTAB1008 Charging Port Replacement: adım 9, 3 resimden 1. Vizio VTAB1008 Charging Port Replacement: adım 9, 3 resimden 2. Vizio VTAB1008 Charging Port Replacement: adım 9, 3 resimden 3.
    • Flip the motherboard over.
    • Directly underneath the USB Charging connector will be four solder points that need to be undone in order to remove the charging port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,267
