Giriş
Hello! This is a guide on how to replace the charging port in your Vizio VTAB1008!
Neye ihtiyacın var
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
Bir başkası bu kılavuzu tamamladı.
