Giriş
Hello! This guide will help you replace the Wi-Fi antenna in your Vizio VTAB1008.
Neye ihtiyacın var
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Using the blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
Neredeyse bitti!
Sonuç
