Ana içeriğe geç
VooDooQuad 250 Propeller Replacement
Neye ihtiyacın var
    1. VooDooQuad  250 Propeller Replacement, Propeller: adım 1, 2 resimden 1. VooDooQuad  250 Propeller Replacement, Propeller: adım 1, 2 resimden 2.
      • Unplug the power cable of the drone to eliminate unnecessary mishaps.
      FixBot'a Sor
      Yorum Ekle
    2. VooDooQuad  250 Propeller Replacement: adım 2, 1 resimden 1.
      • With your set of pliers loosen and remove the four bolts holding the propellers to the motor.
      FixBot'a Sor
      Yorum Ekle
    3. VooDooQuad  250 Propeller Replacement: adım 3, 2 resimden 1. VooDooQuad  250 Propeller Replacement: adım 3, 2 resimden 2.
      • Gently remove the propellers perpendicular to the device.
      • When placing the new set of propellers on the drone, make sure that the wings angled upward are facing towards the center, or the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Be careful removing the bolts multiple times because it may create slippage and then this will not allow the bolt nor the propeller to stay on. To reassemble your device, follow these instructions in reverse order
Bir başkası bu kılavuzu tamamladı.
Damir Pamic
141 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 10-3, Remmell Spring 2017 USF Tampa, Team 10-3, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S10G3
4 Üyeler
1 Kılavuz yazıldı
1Rehber Yorum
Where do I purchase new perpelers
Will Smith - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 1,000
